Hi, I thought this would be the correct section to post this question. Umm, I have lowered my '72 Satellite to the point where the rockers are 7'' off the ground. I don't have the center chunk installed in the rear end housing, and I don't even have a driveshaft for the car yet. My worry is... what if the driveshaft ends up in a straight line with the transmission yoke? I understand that universal joints require an angle of some sort between the two moving parts. Does anyone have a thought on whether or not I should be concerned about that possibility? I really do not want to change the ride height of the car because it looks perfect with the size tires that I bought. I tried to add pictures to this post, but I am puzzled about that situation too!
Thanks!
