.002"? Measured or plastigaged? That should be plenty of clearance provided the crank was ground without taper and the main bearing bores were correct when you assembled. You might want to think about replacing the main bolts too. That cap's parting line looks a little strange to me.
Well, art is art, isn't it? Still, on the other hand, water is water! And east is east and west is west and if you take cranberries and stew them like applesauce they taste much more like prunes than rhubarb does. Now, uh... Now you tell me what you know.
