i dont plan on rock crawling with it , instead i think im going to put the town wagon body i have on it and use it to tow my rock crawler . there will be more beef added to frame as i go , ill be adding tube thru the frame to join the 2 pieces together and once drive train is in as many permanent cross members i can get away with
![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
more progess
took the 30 spline 60 out and put in a sterling 10.25
![](http://i190.photobucket.com/albums/z219/penski61/work/IMG_20151105_171349237_HDR_zpsdacgxn9p.jpg)
while i was at the junkyard removed coil buckets off an 07 superduty , drilled some new holes in them so i have 3 positions of height . going 3 link because the leaf springs would have had to been relocated anyway and figured might as well get a little better suspension
![](http://i190.photobucket.com/albums/z219/penski61/work/coil_zpsypan3z0a.jpg)
drilled the holes in the frame and added tubing then welded them in so the frame wont crush when bolted in
![](http://i190.photobucket.com/albums/z219/penski61/work/IMG_20151107_162001054_HDR_zpsgjy9vxpm.jpg)
![](http://i190.photobucket.com/albums/z219/penski61/work/IMG_20151107_162024770_zpsaczuwhan.jpg)
![](http://i190.photobucket.com/albums/z219/penski61/work/IMG_20151107_171752033_HDR_zps1askcjmh.jpg)
![](http://i190.photobucket.com/albums/z219/penski61/work/IMG_20151107_171742692_HDR_zpscmhaw7uc.jpg)
