Originally Posted By nss guy
Originally Posted By dannysbee
The A&A manifold is based on the 1964 intake. They make it in 3 versions. As cast 440 ports, cnc 440 ports and as cast max wedge ports. I'm pretty sure Guy replaced a Mopar performance reproduction manifold with the A&A and picked up a tenth or so. He is running the max wedge port intake.
exactly as stated, before the mopar performance intake I ran an original 63 intake that had the the 4 hole centers cut out for the larger bore carbs, the A&A is definitely faster then the mopar performance and the original intakes. now the 440 port intake ??? what are you going to compare it to? the look is perfect, performance ????
My initial question was regarding fitment and quality.
