Well, you're only at the beginning of the block prep...Depending on what I see IN the cooling passages I treat it to a muratic acid cleanout...After I'm happy with the de-rust/de-scaling...I use Eastwood's oxysolv or Ospho as Scott has suggested...That makes for a nice,clean block the paint will easily adhere to...
