Quote: I only have one cam BradH, the one that Ma Mopar installed into it June 1970.
Did you have anything that you can add to help our Mopar community find any answers as to which cam it was that was put in?
Measure yours and see if it's w/in approx. 1% of the #s below, which came from an OEM 440 HP cam w/ about 8000 miles on it. If yours is significantly different (smaller), then it's not an HP cam.
