You could shorten the front vertical down leg to the right length so on the other end when it is bolted down it almost touches the intake but ain't that a very large hole for the return spring as in does that bracket (originally) go to something else? EDIT With more thought the hole seems big enough for a PCV or PB hose ??? just wondering
