Originally Posted By 76dodgeboy
Is it possible to do with the rotating assembly in?
It might be tuff shruggy I don't do them that way, I installed them on the engine stand with the main bearing bores with the caps off pointing up, I install the last(the smallest one) bearing on the tool and install it, on the rest I install them onto the tool in the block so I don't damage them while working the tool through the other cam journals with the bearings installed on the tool twocents
