The magnum manifolds work. I would use them as they flow better the the center dumps. Get a internal balance converter for the 727 or take the weight off the 360 converter. Your stock kick down will work assuming you are buying a magnum intake manifold. Lokar makes a nice kick down cable kit that works well and does away with the linkage.
