Originally Posted By STROKIE
It's not a drag car, just a occasional strip... drive
https://www.youtube.com/watch?v=tt-x-_3jjmE
Understand, but still not a good idea from a safety standpoint. Weather you are cutting out the front or rear brakes, it should be done with a momentary switch operating a solenoid and the system should be energized with a SPST toggle switch ( with an arming light if possible ). A little more work, but you could hide most of it easily enough. beer
Fastest 300
