What Mopar V8 has the dipstick going into the oil pan except the class A motorhomes and large trucks? If it is broken off in the block I use a 318 pushrod from the bottom with the oil pan off, to drive the old piece out thumbs I have tried to use a flat nose punch to drive that piece out and ended up buggering the block up down whiney
