Originally Posted By 451Mopar
PACT sells a heavy duty overdrive spring for $70.
Problem with that is the extra pressure has to be overcome when the OD is engaged and this robs apply pressure from the OD clutch pack along with putting extra load on the bearing that carries the spring pressure. This is what makes the Mopar OD trans inferior to most others.
The INTERNET, the MISinformation superhighway
