I fit ALL THE RELAYS under the dash ( hidden by kick panel ), and took the power from ammeter stud, alt side.
didn't cut a wire, simply removed the terminal from original foot switch plug, instaled on relay plug, and run back the other wire ( signal ) on same color between foot switch plug and relay plug with new terminals, so you'll never see a relay anywhere or diff color wires, or splice anywhere.
made teh same on each speed of A/C-Heater.
relays are away from engine bay heat, dust, grease, water and rust caused by elements. and won't tell any splice or added device on engine bay
Great, except you've missed the main point of the conversion....Your still feeding the power throught the bulkhead connector..
NO BECAUSE I MADE THIS:
charging upgrade
If you need more info about that will search the link where we heavily discused here on moparts
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
