Its plugged into the power port on the left side as u look at the front of carb. Full vacuum.
The choke seems to work ok. edlebrock carb and 361 motor. I pulled the intake off today and saw that there is a film of out between the pan gasket and the head. This was installed without the gaskets that come with the pan gasket, I hear so much about everyone not using the gaskets. I'm going to replace the pan gasket and use all 4 gaskets this time and see what happens. I know it a pain to get it all lined up. Alex
