Originally Posted By ahy
Sounds like I have a winter project... I'll do the pan first and go from there.
Good idea, do the pan first and see if that solves it. If not, you can always add the accusump which will solve it but is expensive and heavy and somewhat complicated.
By the way, when you install the road race pan go ahead and add an oil temp sending unit at the same time. Once you start watching oil temp you'll learn a bunch.
