Re: Anybody know how much cfm a 4" throttle body flows?
[Re: Slingshot383]
#191197
01/12/09 04:39 PM
01/12/09 04:39 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Does it have the barrel valve? You'll need a pump, mounting brackets, either a crank drive mandrell, or a cam drive unit, a 3-way shutoff valve, and then send the whole works off to get it flowed to match your motor. If the current owner has the info off his motor, including what pump he was using iand what it flowed, $1000 may not be a bad price.
I don't know if it has a barrel valve or not. The current owner bought it used and doesn't know much about it other than it was on a tractor puller called "Fire Dragon" lol. So it's probably a little more than I need, ha.
