I'll post it here too;
Wrong bushings, correct ones are off-set.
Can only find pics of Poly replacements in the correct config, Ebay auction.
And:
The FACTORY original front sway bar bushing had a profile like this on all ’70-72 B-bodies, the bar is off-set to one end slightly. Any aftermarket bushings having the bar pass through the center of it is NOT correct for this application, bar contact with the bracket (as pictured above) will be the result of its use. The MOOG part is wrong for this application period.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
