What is the best way to disassemble a motor that is stuck. 383 been sitting many yrs in a shed on the back of the block upright, cyls were filled with oil, but too late. I have it down to the crank, rods and pistons. I don't care about the rods or pistons, but the crank journals look good and the block should be.
How do you get a stuck motor apart? Would like to not be as "crude" as possible, but the motor is going to be taken apart.
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
