I use a Daytona Sensors WEGO IV and a GoPro to record everything while making a pass. I can see the AFR, the tach, shift light and when I shift, oil pressure, fuel pressure, water temp, trans temp...And listen to what the motor is doing the whole time.
Camera was loose. DOH!
https://youtu.be/B2Bcne-I894
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
