Strange axels have a much shorter hub(narrower) than the factory axels. The wheels I'm using are steels. The car has drum brakes and the hubs do not protrude into the rim at all.
My belief is that it does not matter as the wheels are lug centric.
This is no different than my centerline wheels on the Cuda(the hub does not protrude into the rim either)and the lugs on those rims also center the rim except instead of a conical lug it uses a collared one.
A friends believes I'm going to shear off the wheel studs at the track. So please help me settle this. He keeps referring to hub centric wheels and I've explained that older Mopars did not use those.
