Lots of good oils out there. But from what you posted, I would run Brad Penn semi-syn with either 10W-30 or 20W-50 viscosity depending on how hot your oil gets. If the HOT oil idle (1000 rpm) is below 25 psi, then use 20W-50.
I have been using Brad Penn for many years. 10W-30 in my drag race engine, and 20W-50 in my 440 street car with a partial block fill (oil gets hot).
