What Feets said & 15 (confirmed with a good gauge) ain't gonna cut it. not sure where the prob is but I would definitely dig in. not sure if the additional flow from the oil thru pushrods is the cause or not (I'm thinking not) but that (might) be the first thing I'd swap & check further on that situation (& check preload while you are at it but that is unrelated to the psi).
