Originally Posted By BigBlockMopar
There are Apps for that.
Pretty much every modern smartphone can be used as a angle finder.
Tremec has a cool driveshaft/trans/diff angle one too I've used a few times now. up
The most tricky part is being able to mount the phone securely/square
What if you get a call in the middle of an alignment? laugh2
work
New voicemail idea...
Hi, this is Jeff...sorry I can't answer your call but I am setting my camber at the moment. Leave a number and I'll call you back when I am at 3/4 of a degree negative.
biggrin
