The trick is to use the Chevy rods. They are made in much higher volume so you can get higher quality rods for less money. For a 512 you should be able to use a very common 6.535 rod. Another great benefit of using the Chevy rod is that then you can use Chevy rod bearings. There are a ton of those bearings available including different widths, coatings, etc.
If it was me I'd probably go with the Molnar crank, some SCAT H beam rods and the SRP pistons. That combo should fall together and make really nice power with the TF heads.
Well Andy you are real close to what my list is, only diff is Eagle rod's and Ross pistons, I will look at the Scats and srp's
