ECU is built in, ie you do not run a chrome box, orange box, etc. Two wire hookup usually. One wire to power, one to coil if memory serves. The one I used to have ran a hall effect sensor instead of an old school magnetic pickup, supposed to deliver more accurate spark timing. One thing I wonder about them is how easy/hard they are to adjust the advance curve.
