It's hard to say what is causing the flooding, but if rebuilding it properly doesn't eliminate the flooding, then the integrity of the carb is in question. Clean the parts real good and look for cracks in the main body before you assemble it. One thing to watch out for is, make sure you install the 2 rubber O-rings between the main body and the top air horn.
