As silly as it seems, get the handles of both wrenches within 20 degrees of one another and wrap both hands around the both wrenches. Squeeze them together to break it loose. It sometimes works for me when I'm dealing with something stuck hard.
As stated earlier, if you can't get box end wrenches on there then use line wrenches.
Open end stuff is not your friend in this situation.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
