If this is a once-in-a-lifetime build do it right and spend the extra couple of thousands for a block that won't break. There are plenty of posts on this topic.
Most aluminum blocks have cast iron cylinders so wear shouldn't be an issue. And even the OEM blocks with spray-in liners have to last 100K or more.
R.
