You might try using a section of heater hose between the carb and your ear to locate where the whistle is coming from. Had a friend that complained he was getting a whistle coming from a carb I had rebuilt for him. Found the problem with three feet of heater hose. Turned out to be a sucked intake gasket. Same trick works for diagnosing water pump and alternator noises too.
July 19th should be "Drive Like Rockford Day". R.I.P. Jimmie.
