Sorry guys, I pulled the tape off the harness under the dash, tested the ignition switch, which is good. I found the problem, the new m&h harnesses has a pigtail for charger hideaway headlights (2 blue wires with white stripe) they told me to cut it as I didnt need it and tape it up. Well wouldn't you know its the same wire from the ignition switch, cutting that wire cut the circuit.
Car starts!!!!
New problem.
Its the mopar orange box, all brand new wiring
Car doesnt shut off when the key turns off.
any thoughts?
