70 roadrunner with 70 amp alt. constant output voltage regulator 3690731. been having miss in motor which turned out to be connection at ballast resistor. While trying to track down problem measured voltage going to ballast and it was jumping between 16 volts and 18 volts when car is running. 11.5 when not. Question is, this means Regulator is bad?
