Just hot wire the clutch to see if it works, if it doesn't work with 12 volts and a ground to it then the coil in the clutch is bad. Either replace the clutch or the compressor. This happened to my 99 ram. Worked fine then quit working all at once. put new compressor and it's just like new.
