Hello BigmoneyLewis
How is the radio controlled after a conversion?
how's the channels changed?
can you use x fm satilite radio?
Didn't see on the web site where it explained this??
Your radio will work exactly as it does now . The five pushbuttons will work , the tuner knob changes the stations exactly as it does on your stock radio .On off vol, tone control all will work as factory . When you turn the radio on you are in FM stero , to switch to AM simply turn the radio off and back on . To play an aux device, simply plug it in and it will play ..
unplug it and it goes back to FM stereo . You can listen to satellite radio as well . And we can throw in blue tooth for an additional $ 25 . The radio I shown is a '67 GTX , but we do most all A B E body as well as most Ford and GM 1960-1974 .
Greg
