I'm asking if you have a drum style master cylinder. It sounds as if disc brakes were swapped on the car. If you have a drum style master cylinder, it needs to be modified to release the pressure from the calipers. Drum and disc masters are not the same and the valve needs removed from a drum master to work with disc brakes. The valve is where the brake line goes into the master cylinder.
