Bob Banning Dodge used to get about 90 runs at roughly 1800 hp on 80% nitro in their funny car back in the 70s. They would typically crack in the main saddles. When you had to chisel the main bearing out because it got drawn up into the crack it was time to replace the block.
Then I should be way safe then!!! Thanks Has anyone else ever seen a factory block like this?
