I just ordered (
http://www.sdtrucksprings.com/air-lift-60818-air-spring-kit-dodge-ram-1500-09-14? ) for the truck today. I also hocked up a $35 backup camera that works great so far and a power tailgate that also works great. I hocked that up to p door pop (the second pop on the key fob )
When i put the air lift on i will add cables to the shocks so the spring don't came out when you jack it up. So far the ride is the same as be for.
If l never told my wife what i was doing she probably would of never noted.
good luck
