Rebuilding my Saginaw pump for my challenger SB, what spray bomb paint have you used with good results (i.e. it lasts pretty well under the hood). Do you use primer?
I don't have to get the exact factory finish but I believe is was semi-gloss so something that is close enough would be fine.
What do you use? Chassis Black? Something else?
Thanks!
