Here's one more photo that should have been included between E and F. The upper cable is the long rear P brake cable going to the R wheel. Below and to the right is the back end of the front-to-rear brake line. The flex brake hose and the brake line join in the bracket hole.
Note the bracket has a notch to catch the P brake cable.
If you don't see two dolphins, you need a vacation.
