1 - Yes, you need a kit with the rivets for a 'glass hood.
2 - Yes, lighter springs, hinges are the same.
3 - Same rear seal.
3.5 - Front seal to radiator support has the ends trimmed off.
4 - Same molding, but you use longer studs. R/T Specialties has them.
5 - No emblem.
6. Same as any other 1970 hood.
7 - www.fpap.com has them for sale.
8 - See 3.5 above.
9 - Pins only, no center latch or pop up spring.
