blew a tranny line yesterday, going to make a new line, and not real bright on the fitting ends, can someone please tell me the correct size and type of fitting i need to hook up to my stock trans connection ( male threads come out of trans) and size type i need to put on other end lower radiator (also has male threads coming out) thank you for any help, need to order the correct fitting for each end so i can custom bend line thank you
