I'm almost sure that Total Seal doesn't make, use or recommend a gapless ring in .043, if they do I wouldn't use them Get a really good set of rings for the dual purpose appilcation with that much compression I'm not sure if the top should be moly and a second Napier iron ring or which package is the best for your deal, sorry
