A noise sometimes described as a squeal or whine is often caused by a rapidly cycling pressure regulator valve (there are a couple of TSB's on this). Factory fix is to replace the valve body but a fluid/filter change will sometimes stop it.
It's more on an annoyance than a real problem.
The INTERNET, the MISinformation superhighway
