Quote: Rapid340, can you share details on your engine combo?
Its a stroker 340 with production iron heads, intake, and thermoquad that I ported and set up myself. Over 11:1 compression, solid FT cam. Nothing at all done to the exhaust manifolds, 2.5 inch full length pipes with dynomax utraflow mufflers.
If you need a cam or carb for an application like this, PM me.
