Look at some dyno sheet... A 440-1 indy head on a 500“ motor will make 100% no problem. My home ported iron heads went around 95% VE.
Especially at low boost
I didn't do anything on the turbine calculations because I was just pointing out the compressor mismatch. You can use this tool for wastegate and turbine calcs tootoo.
A 75mm on a 500“ motor not work well.
