Question ....
Is there anyway to identify an AMD shaker hood say by weld types, weld locations or some type of stamp? Something that AMD did to internally identify it is their product.
Other than the underside bracing.......
for example - say someone purchases the AMD hood and takes the underside embracing off and installs the real OE bracing on the hood. and does it in such a way that the spot welds are "spot on".
Also - was wondering if all OE hoods and NOS hoods had the EM 0Dxxxxx stamped in them.
thanks in advance.
Got me a NEW Project 1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior. Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
