I have copy of the factory Mopar TSB for the 1970 Barracuda grille whistle noise issue. It tells you to place strip of black tape over the entire length (top and sides) of the joint area between the grille and bezel molding upper surface ?? I could use some help/ clarification or pics for the exact placement of the tape to stop this noise. Has anyone already done this with good results ? My 70cuda currently has this aggravating whistle noise.
thanks DOUG. send info to ( dougandcindy@eastlink.ca ).
