Originally Posted By Sammy
A power brake booster.
How the heck do you get the plug out. The booster is right in the way and no way can I get a extention or socket in there.
Any tricks to remove the spark plug and then get that flexible boot back on. It's a bear.
You'll need to remove the 4 nuts (pictured below) on the backside of the booster, disconnect the linkage from the end of the booster rod, carefully "rotate" the booster off towards the drivers side, no need to disconnect the brake lines or master cylinder, just "relocate" the booster...this is the way the factory intended it to be done...
FYI...be sure to remove the compression washers from the new spark plugs you may be installing, they are not needed/nor used on the HEMI, if the plug your pulling already has compression washers on them, hopefully they didn't distort the plug tubes?...causing oil leaks into the tubes
Mike
