Originally Posted By hooziewhatsit
I measured to get close... then I ended up pulling the pushrod out of the booster, gently setting the MC in place (keeping it square), then seeing how much farther in I could move the pushrod. Currently have it adjusted to zero, with no apparent brake dragging. shruggy
Apparently you're also supposed to be able to look in the master and see a poof of fluid when you press the brake pedal an inch or so if it's adjusted correctly (with everything bolted together).
As previously mentioned You need to have .030 clearance between the pushrod and piston when the pedal is released.
