Would a switch to aluminum heads allowed you to keep running the 38 degrees of timing and resulted in even more of a power jump?
JMO but if you ran higher timing on the alum head VS less timing on a iron head that it would be the same.. if both heads were the same thing and just different material... again... JMO
