Back in the early 70s I had a '71 Plymouth Valiant Scamp with 225/727 & 8.75. Made in Canada. I was interested in Time Distance Rallying back then and nearly every Friday night there was a rally that started in a parking lot and went through the surrounding countryside in King and Snohomish county. I put radial tires and a set of Addco front and rear sway bars on the car and it was huge fun to toss around. A rear sway bar alone w/o a front bar will cause oversteer if pressed, be careful.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
